Re: No spark
Posted by CNKS on May 16, 2007 at 18:26:20 from (204.249.178.32):
In Reply to: Re: No spark posted by Brownie450 on May 16, 2007 at 18:01:24:
I will try that. As to the points. I got a new set from Carter and Gruenewald. However, the bottom (adjustable) point for some reason is offset and cannot be mounted correctly. Since the old points looked good anyway, I used the new point that is attached to the spring, along with the old moveable one. Dissimilar metals or something? But, shouldn't I get a spark from the coil wire 1/4 inch from some ground, simply by cranking the engine? Or, shouldn't it shock the poop out of me? Again I have current to the + coil terminal, little if any comes out.
