Re: No spark
Posted by D Slater on May 16, 2007 at 18:59:54 from (205.188.116.138):
In Reply to: Re: No spark posted by John T on May 16, 2007 at 18:26:22:
If I remember correct on his tractor the ignition switch wire that is hot when switch is turned on goes to starter button and powers it then from the same side of terminal to resistor so he has that correct if coil wire is hooked to same side as switch wire on push button. If you have a good coil and power to coil I would follow Johns advice on points and related parts and make sure nothing is shorted out.
