Re: Farmall 140 Need Hyd. Link Arm ?????
Posted by SuperA-Tx on May 16, 2007 at 19:15:24 from (4.90.2.125):
In Reply to: Re: Farmall 140 Need Hyd. Link Arm ????? posted by Gene-AL on May 16, 2007 at 18:03:24:
Gene, The lift link for the SA and 140 are quite differant. For example the front part of the link rod on the SA ends in a flattened part that just has a hole drilled in it. On the 140 it has a large "hook" where the front attaches to the hydraulic unit. The rear of the connecting rod is somewhat differant too, spring is huge on a 140 compared to a SA. Plus if I remember correct there is a square plate between the lift rod and the rockshaft arm. The arm on the 140 is lots thicker than on the SA. You (cant remember) can adjust the lift collar on the 140 but you cant on the SA, its welded in place. The 140 also has the assist lift spring (differant thing altogether and not even on a SA). So what someone has done on his is take the hook part and welded it on a pipe (I guess). I dont know what they did on the other end where the spring fits. There is two nuts that go on there to hold that spring. PS. The bolt that holds the lift arm to the front rocker arm off the PTO is a half inch bolt. I checked on them at Case and they wanted $8 each. I made some myself out of a half inch hex head bolt, cut it and ground down the head. Head of the bolt is kind of rounded so it is pretty easy to do. get a long bolt where you can cut off all the threads.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
