Re: No spark
Posted by John T on May 16, 2007 at 19:52:38 from (66.244.83.147):
In Reply to: Re: No spark posted by CNKS on May 16, 2007 at 18:45:34:
You can take the distributor cap n throw it away but stillllllllll any time theres voltage to the coils high input and its output has a ground path via a good set of closed points buttttttt the points are opened THE COIL WIRE SHOULD FIRE to ground.
If the coil wire fires but no spark getting to any of the plug wires, its EITHER a cap or rotor problem or the wrong cap or rotor etc.
John T
