Re: No spark
Posted by Gene-AL on May 16, 2007 at 20:14:46 from (74.226.29.14):
In Reply to: Re: No spark posted by CNKS on May 16, 2007 at 18:15:36:
CNKS You say: "If I could get current TO the distributer, I could check things out." My take is that you probably have current THROUGH the distributor, but it is to ground all the time, and no spark can occur until the ground is opened. If I read you right, you have a short to ground or a partial short (resistive) path to ground at the coil (-)lead or inside the distributor on the same connection. Possible places are: 1. The connector through the distributor wall has a broken/missing insulator or metal parts attached to the feed through bolt (if that's what it has) are touching the distributor case (ground). 2. The condenser is leaky/shorted or its lead/connector lug is shorted to ground. 3. Your points never open which might include some part of the points 'hot side' from the feed-through touching a ground. Have you carefully inspected the points? They also have an insulator which is the bearing that they move back & forth on. How about the points mounting screws - could they somehow cause a short by touching one of the places I've mentioned? You could take the coil (-) wire loose from the distributor and, with the ignition 'on', see if you get a small spark at THAT wire when you touch and remove it from a ground (it should also produce somewhat less than a full high-voltage spark at the coil high voltage tower because no condenser is connected). If this proves to be the case, then your trouble would seem to be within the distributor itself. I see nothing wrong with your description that the ignition key switch 'on' wire goes to the starter switch then the SAME wire connection continues on to the resistor, then the other resistor end to the coil (+). The OTHER connection on the starter button switch goes to the solenoid AND also direct to the coil (+) for 12V direct to the coil while the starter is operating. I have no diagram of this tractor to go by, but I believe what I have stated should be correct, based partly on what you wrote.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
