Re: No spark
Posted by KEB on May 16, 2007 at 20:53:50 from (72.19.170.5):
In Reply to: No spark posted by CNKS on May 16, 2007 at 17:34:07:
Here's an easy check. Connect a test light between the (-) terminal on the coil (the one that goes to the points) and ground. An analog voltmeter will also work, but a light is easier to see. A digital voltmeter is not good for measuring pulses like you expect to see. Turn the ignition on & crank the engine. You should see the light pulse on & off as the points open & close. If the light pulses, but you don't have a spark when you hold the high tension wire coming out of the coil next to ground, either the high tension side of the coil is open or the high voltage wire itself is bad. Replace as needed. If the light never comes on, disconnect the wire to the distributor from the (-) terminal, leave the test light connected, and turn the ignition on (don't have to crank). If the light comes on now, you have power to and through the ignition coil and either the points or the wire between the (-) coil terminal and the points is shorting to ground. If the light still doesn't come on, check at the (+) terminal with the ignition on. If you have power at the (+) terminal but not at the (-) (with the wire to the points disconnected), the primary side of the coil is open and it will have to be replaced. If the light comes on and stays on, the points are not closing. First place to check is for an open circuit in the wire between the (-) terminal on the coil and the points. Its common for the points wire to either short or break inside the insulation where it enters the distributor. Good luck, let us know what happens. Keith
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
