Re: What to do .....13' disc---560d..??
Posted by Hugh MacKay on May 17, 2007 at 03:04:53 from (216.208.58.170):
In Reply to: What to do .....13' disc---560d..?? posted by Clefus on May 16, 2007 at 17:39:54:
Clefus: Lot of different specs out there on any particular width of disk. Size of blade makes a big difference, as well as blade spacing and weight per blade.
You didn't tell us what model the Oliver was. If it was a 1650 or 55 and grunted then your 560 is going to grunt. If it was one of the larger Olivers that grunted, you may have a boat anchor. Then you must consider the current condition of both tractors. Back in 1967 I tried both Farmall 656 and Oliver 1650 on demonstration both new tractors at the time. On brute strength and lugging ability, I've got to give it to the Oliver.
