Re: Basket Case Tear Down Part 5
Posted by Bill46 on May 17, 2007 at 10:01:42 from (65.200.157.177):
In Reply to: Basket Case Tear Down Part 5 posted by neblinc on May 17, 2007 at 05:35:07:
I usally take a 2" piece of flat steel 1/4 inch thick and drill a 1/4 inch hole in it. I then arc weld it thru the hole to the flat of the bolt head. Let it cool and bend the steel up a little like a handle. Work it back and forth a little and it comes out.
I just did the broken bolts in a 656 rear axle housing...worked like a champ.
Grandad taught me that years ago. I am not a very good welder, but it still works for me.
Something about the bolt expanding and cooling in the housing helps it work.
Good luck.....
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
