Re: B steering
Posted by CENTAUR on May 17, 2007 at 10:45:36 from (75.28.3.132):
In Reply to: B steering posted by teddy52food on May 17, 2007 at 10:16:07:
Is the exsisting joint welded at each end? You might consider a Automotive IMPACT U-joint.You might have one with the socket end broken that would work just fine.The plain black oxide finish leaves the tool steel easy to work with.You can drill it,grind it and tap it.Do not use the chromed as they are brittle and HARD.CENTAUR
