Re: To change or not to change...that is the quest
Posted by Janicholson on May 17, 2007 at 20:14:15 from (66.173.50.154):
In Reply to: To change or not to change...that is the question. posted by Patrick Martin on May 17, 2007 at 19:42:02:
Put the rings into the cylinder they go into just at the top of the wear. (where the top ring stops. (be sure that they are right side up, and square in the bore. Measure the end gap of the rings (one at a time) if they are more than 50% larger than specified for new, the rings are toast.\
Google piston rings, Ill bet you can find a source that will sell you the pieces you need. JimN
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
