Re: Update on cub and A
Posted by El Toro on May 18, 2007 at 03:57:42 from (205.188.116.138):
In Reply to: Re: Update on cub and A posted by 1941 farmall a boy on May 17, 2007 at 18:44:24:
third party image
If your mag is going to require a lot of work and expense you can convert your mag to a distributor.
This can be done without removing the mag from the engine. You would only use the points and condenser that's in the mag. Since you have battery start you would need to buy an automotive type coil and some auto electrical wire. You would need to buy an ignition switch too. Here's a picture of an IH farm tractor that has been converted. Just something to think about. Hal
