Re: Farmall C Magneto Timing Problem
Posted by Paul f on May 18, 2007 at 05:22:13 from (63.163.109.121):
In Reply to: Re: Farmall C Magneto Timing Problem posted by Yugrotcart on May 17, 2007 at 17:20:09:
That seems to be the problem...I get the engine to TDC and set the mag to #1 then install it. When I rotate the mag out it won't trip. If I remove the mounting bolts so I can rotate the mag out even further it will finally trip ..but the mounting holes are then not usable.
