Re: International farmall 656 gas in crankcase
Posted by Janicholson on May 18, 2007 at 20:47:05 from (66.173.50.50):
In Reply to: International farmall 656 gas in crankcase posted by Reyweihaupt on May 18, 2007 at 19:50:07:
Always shut off thefuel at the tank. Your float stuck and the fuel ran into the engine and down the cylinders into the crank case. If it survived the lack of lubrication, it is a miricle. You probably need a needle and seat in the carb. But still turn off the fuel when stopped for more than 5 min. Though it seams impossible to get there, it does. JimN
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
