Re: Farmall MD questions!
Posted by georgeky on May 19, 2007 at 09:18:34 from (152.163.100.197):
In Reply to: Farmall MD questions! posted by jonnnny2006 on May 18, 2007 at 20:02:17:
Take that thing home and get the gas components to working like it is suppose to. It is the same as any gas tractor, spark+gas+air = running. It has to be changed back to gas in the shut down process to avoid head damage. They are not near as complicated as some folks think. I knew nothing about one and bought a 450 not running, that had sit in a barn for 14 years, brought it home cleaned tanks and carb, checked out distributor made sure I had spark. After all my inspections and cleaning of fuel lines and so on it would not start on gas, so I pulled it 10 feet and it fired right up. Then I completed the bleeding process and threw the lever and it changed right over and ran great. Since then it has started with the starter every time just like it is suppose to do.
