Re: Farmall C problems (kinda long)
Posted by Janicholson on May 19, 2007 at 16:15:01 from (66.173.50.4):
In Reply to: Farmall C problems (kinda long) posted by Karl Hamson on May 19, 2007 at 12:24:45:
With a open coffee sized can at hand try this;
With the float bowl cover off, gently hold the float upward with finger tip pressure. (it should be about level) then turn on the fuel at the tank. If fuel comes out turn it off and claen the needle and seat. it probably has a bit of trash in it. If it does not, hold the can up there and let the float down to see fuel comming out. then lift the float to shut off the supply. Then turn off the fuel at the tank. and reassemble the carb bowl. (always turn off the fuel at the tank, when shutting it off for more than 2 minutes! (I am serious about this, it is gravity feed and can fill the engine/start a fire, or both). JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
