Re: starting troubles
Posted by John T on May 20, 2007 at 07:43:31 from (66.244.83.147):
In Reply to: starting troubles posted by Pat-CT on May 20, 2007 at 07:00:33:
Pat, if the carb is set too rich or theres an inlet air restriction cuz the air filter is clogged or the chokes not full open she can black smoke out the stack which can foul plugs fairly easy causing hard starts or a miss. If you havent already its not that expensive to install new plugs (gap correctly) n points n condensor and then adjust the carb n see what happens. In the meantime you may get by to clean the plugs n clean n re gap the points n adjust the carb leaner n see what happens. None of this is rocket sciene or very expensive, a good general ignition tune up n carb adjust may well be all you need
John T
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
