Re: Still no start
Posted by Brownie450 on May 20, 2007 at 11:43:42 from (207.177.82.245):
In Reply to: Still no start posted by CNKS on May 19, 2007 at 18:26:25:
Is the manifold hanging up on the manifold bolts/ studs, or is it not flat? If it hangs up on the bolts/ studs, you could ream the mounting holes to the next size & see if the fit is better. If it is not flat, to get the tractor running, use 2 intake gaskets with Permatex# 1 or epoxy metal between them to take up the gap. This route would only be a temporary fix until you had more time.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
