M brake/clutch/hydraulic shaft bushings???????
Posted by Patrick Martin on May 20, 2007 at 16:32:13 from (64.154.26.250):
Hey guys, the clutch, hydraulic, and brake shafts on one of my M's are wobbly. Is there a fix for this?
I'm still waiting for my I&T manual for this series ao bear with me! :)
I haven't started tearing the rear half down yet but I did get the pedals off and the arm on the hydraulic lever and I noticed the seemingly excessive play on these shafts. Are there bushings or bearings with seals that can be replaced that will tighten this or will I need to build the brake housings and port for the hydraulic lever back up with weld???????
