Re: new question
Posted by CNKS on May 20, 2007 at 18:39:48 from (204.249.178.32):
In Reply to: new question posted by Diana JH on May 20, 2007 at 18:07:28:
Manifold heat control valves circulate hot exhaust gas to near (not in) in intake mainfold to keep the engine running smooth when cold. When warm the valve (usually a flapper) closes and prevents most of the hot exhaust gas away. Yours is probably stuck open, meaning it will get the exhaust all the time, perhaps heating the mixture more than it needs to be heated -- a relatively cold mixture is best in an engine at operating temperature. If it is stuck closed, it will run rough until it warms up. May or may not be important to you, depending on what the temperature is where you use the tractor. On my 460, same problem as yours, I broke the bolts holding the two halves of my 460 manifold together, ruined both halves trying to get them out. $$$.
