Re: new question
Posted by Hugh MacKay on May 20, 2007 at 20:40:47 from (209.226.247.138):
In Reply to: new question posted by Diana JH on May 20, 2007 at 18:07:28:
Diana: I've just finished reading this thread. This 350 diesel, and I'm sure you know this, is one of the few times IH went to an outside supplier for and engine. Until you strike a guy like George who has one most of us IH folk know very little about them. You'd probably get better info from Cockshutt or MH guys than IH guys that never had a 350 diesel. That Continental is forign to most of us. Every diesel tractor we were used to up to 350 days were gas starts. The ones that followed were all glow plug engines.
By the way I have folowed the other thread. I must confess I was quite surprised back when you sent the tractor out for wiring and other service. I could see sending it to have the chloride removed. At the time I felt you were quite capable of doing most of what needed to be done with the tractor. I could see you removing starter or generator and sending off for rebuild. However the wiring harness, items like air cleaner, switches, heat in manifold, etc. I felt at time that along with YT help you could have done most of it. Seems like you are about to do most of what you sent it out for anyhow.
These old tractors are economical as long as you can do most repairs yourself. Soon as you start sending them out for every repair, then you may as well be running new tractors. Shops are full of mechanics that have no respect for old machines. A lot of them would sooner destroy your tractor than fix it.
I would suggest you give Tom back the battery. All the years I've run dual battery systems, be they 6 volt in series or 12 volt parallel, I've never put a used battery alongside a new battery. If it was two 6 volt I always used the good left over battery in one of my 6 volt gas tractors. If it was two 12 volt wired parallel the left over good battery went to car or pickup.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
