Re: Got my MD home today!!!
Posted by El Toro on May 21, 2007 at 03:56:05 from (64.12.117.8):
In Reply to: Got my MD home today!!! posted by jonnnny2006 on May 20, 2007 at 23:29:54:
Are you referring to the coil wire that is connected to the mag and the other end of the wire is connected to the cap?
I hope you made a note or sketch where the rotor was pointing when you pulled the mag. If you didn't you will probably need to bring No1 piston
to TDC on the compression stroke. Then turn the rotor to the No1 plug tower. You should clean those points with some 320 wet or dry until shiny.
Be careful with the gears in the mag. Hal
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
