Re: farmall b blowing caps of a 12 volt batter
Posted by El Toro on May 21, 2007 at 04:04:34 from (64.12.117.8):
In Reply to: farmall b blowing caps of a 12 volt batter posted by lori mcdonald on May 20, 2007 at 19:05:37:
Use a volt meter set on dc voltage and measure the charging voltage at your battery. Your tractor engine needs to running at 1/2-3/4 throttle. The voltage should be in the range stated earlier below. Hal
PS: Is there a switch where you can change the charging rate? I think it may have an L or H on it.
