Re: f-4 magneto no spark
Posted by Wild Bill on May 21, 2007 at 19:47:07 from (63.147.9.42):
In Reply to: f-4 magneto no spark posted by Denis in MI on May 21, 2007 at 18:19:28:
Are you sure that it is an F-4 mag? If so then: It should still spark if the impulse does not trip. One of the best ways to bench test is to turn backward with a wire brush cup on a drill and watch for spark, (no impulse being used there.) Did you take the gears out that drive the rotor? If so you may not have the little gears timed right. Being out of time would cause the sparks to not reach the dist cap nipples, and thence, not the spark plugs. If it will pick up a screw driver you have plenty of magnetism. Have you installed on the tractor and put the coil wire to a ground and looked for bight blue spark? If you have spark to the end of the coil wire, but not the SP wires, then probably is the rotor gears off time. There are lots of places that could ground the spark out too. The most likely is where the wire from the coil and the wire from the points meet on the condensor. They like to ground out on the mag case right there because the bakelite insulators get old and crumble. If you are grounding there, cut an old old inner tube up and make yourself some insulators and see if you get spark then. They are pretty simple devices, but I know they can be trying. I went round and round with em before I learned the little tricks that make it all easy. I hope I helped, email me if you need to.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
