Re: URGENT HELP PLEASE, IH 756
Posted by Allan In NE on May 22, 2007 at 03:44:18 from (148.78.243.24):
In Reply to: URGENT HELP PLEASE, IH 756 posted by Huss on May 21, 2007 at 23:21:34:
Huss,
Is there any way you can put a heavy load or a gauge on one of the remotes to check your pressure?
If the remotes don't work either, then you've probably got a cover o-ring, pump or regulator problem to start with because low pressure will make that lift repeatedly "cycle" due to simple starvation.
Also, I’d really suspect this if the tractor just plain won’t lift a load.
I've never owned a 756, but I'm guessing that you should probably see somewhere around 1800 lbs at high engine idle.
Allan
