Re: 450 PTO oil overfilling
Posted by Owen Aaland on May 22, 2007 at 14:47:19 from (65.165.246.166):
In Reply to: 450 PTO oil overfilling posted by Rodger Hall on May 22, 2007 at 12:25:07:
Remove the oil level check plug and drain out the excess oil.
Depending on how long it take to start coming out the breather again, you can decide wheather or not you want to change the front seal in the PTO assembly.
