Re: 756 power lost under load
Posted by K.B.-826 on May 22, 2007 at 16:36:07 from (24.180.143.209):
In Reply to: Re: 756 power lost under load posted by GAF on May 22, 2007 at 12:14:12:
So you must know another way to repair a block that's warped or has been damaged by running the engine with the head gasket blown between two cylinders? The compression in that engine was high enough from the factory to require high octane gas, surfacing the block isn't going to make much difference.
