Re: cub steering 1967 year
Posted by Haas on May 22, 2007 at 18:25:58 from (12.65.54.8):
In Reply to: cub steering 1967 year posted by david in tn on May 21, 2007 at 19:57:37:
The Cub steering gear does not have ball bearings on the vertical worm wheel shaft like the Super A. The Steering arm is keyed to the shaft, but the worm wheel is splined to the shaft. Unlike the Super A, where the steering shaft with the worm gear must come out the front, on the Cub you remove two bolts and the worm and shaft come out the back side of housing. There are no ball bearings at all in the Cub steering gear, only bushings. There is a full worm wheel gear, not a sector, so if you take it all apart, you can turn the gear 180 degrees and have new wear surfaces. All that said, the most likely cause of the play is that the nut that holds the steering arm needs to be tightened, or possibly the bushings are worn out. The nut is a castle nut with a cotter pin. Best to take the axle off to get to it. When you tighten this nut, you are setting the up and down play of the vertical shaft that has the steering arm on it. If it is not tight, then the gear can move up and down when you turn the steering wheel, resulting ins steering play. Tighten the nut so there is no end play and then back off to the first available hole in the castle nut. But while you have things apart, take the nut and the steering arm off to check the woodruff key and the brass washer bushing that is between the steering arm and the housing. If it is worn, get a new brass washer. It would be a good idea to get a parts catalog or look up one on line so you can see how the thing goes together. Hope this is not too confusing.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
