Re: M Governor or stuck float?
Posted by Allan In NE on May 23, 2007 at 03:26:08 from (148.78.243.26):
In Reply to: Re: M Governor or stuck float? posted by HENRY E NC on May 22, 2007 at 20:23:57:
No,
If the float is stuck "open", the tractor absolutely will not start and run. Will just flood and run fuel out on the ground.
Your over-speed problem is caused by something somewhere between the hand throttle, the governor, the carb throttle plate/shaft or the linkages between these parts.
Allan
