Re: 966 popping out of gear when you coast
Posted by the tractor vet on May 23, 2007 at 10:37:46 from (76.212.224.237):
In Reply to: Re: 966 popping out of gear when you coast posted by joe miller on May 23, 2007 at 09:52:16:
Yes on the T/A and the MCV is the the control valve that controls the steering, brakes, T/A pressures for high and low along with the lubing of the rear end and cooling of the hyd. oil. IT takes a couple gauges to do this with the correct fittings and one special test tool and there is another test that rquires a Flow Rater that checks the amount of hyd. oil being pumped by the Hdy. pump on the MCV . this is best left to the guys that have all the toys to play with and know how to play with them . the TelTALE lite is that big red lite that is on the lower right face of the right hand side of the dash and should come on everytime that you push the clutch down or be on before ya start the engine. This lite tells ya that the MCV has lost it's pressure or that the dump valve has been tripped by the clutch , this also allowes for easier shifting of the transmissions . . You also could be sucking air in the center section as when ya slow down all the fluid moves foward and allowes the air to be sucked into the MCV thus causing the T/A to unlock but this will also cause the steering to get stiff and lack of brakeing. You could try running the hyd. a couple to three gallon over full and see if this just goes away .If it does then the next time that the tractor is split a new O/Ring where the speed transmission and range transmission come together will get a new O/Ring if the guy that is doing the work knows what he is doing. On the computer i can not check it out myself and i sure can't make a service call unless you are REAL CLOSE TO me .
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
