Re: Farmall C problem
Posted by LMack on March 20, 2009 at 18:56:40 from (98.66.239.24):
In Reply to: Farmall C problem posted by Alaskapete on March 19, 2009 at 16:18:25:
Check the fuel line. If someone has placed a rubber hose to replace the steel line, it must be cut so that there are no low points. If there is a low point where the line gets below the carburetor, you could get an air bubble that will cause the engine to stop. This FYI.
