Re: CNKS Can you help with axle seal replacement o
Posted by D Slater on May 24, 2007 at 14:19:28 from (71.164.53.132):
In Reply to: CNKS Can you help with axle seal replacement on 46 posted by Butch WI on May 24, 2007 at 08:09:55:
If refering to the oring at outer axle bearing and wheel hub the axle housing shouldn't have to come off. If you can get the hub to slide from splines you should be able to replace from outside, you may have to remove the cap on end of axle housing that has the lip type seal in it to get to oring. Some late 560 tractors used a oring between axle housing and transmission housing but if 460 ever did I'm not aware of it.
