Re: SH dies
Posted by Roger46 on May 24, 2007 at 19:25:15 from (69.58.159.41):
In Reply to: SH dies posted by Todd L on May 24, 2007 at 15:23:19:
My Super H did exactly the same thing last year. It turned out to be a stuck needle valve or float (not sure which) in the carb. I could tap on the side of the carb and it would then run fine. I ended up doing a carb rebuild and it hasn't done it since, but before it would do it every once in a while. Roger
