Re: H tranny noise????
Posted by Bob Kerr on May 25, 2007 at 06:18:14 from (205.188.116.138):
In Reply to: H tranny noise???? posted by jonnnny2006 on May 24, 2007 at 17:58:49:
I have a 51 H I bought a couple months ago at an auction and didn't get to see it run of move. When I got it home I noticed it was super noisy so I checked the rear end grease...full of water! and very little gear oil in it since the water displaced the gear oil and it leaked out through the left rear axel seal. There was no signs of the leak since someone painted it up all pretty. I drained it out and out came some peices of ball bearing retainer (the wavy strip that holds the balls in). I am sure there are other worn out bearings in there. Also all these old tractors use straight cut gears in the rear ends. they are the most effecient and create little or no side thrust under load. straight cut gears have one drawback and that it they are noisy compared to helitical cut gears used in cars. If you have ever driven an older car with a stick shift tranny you may have noticed reverse makes a whining noise compared with the forward gears. Reverse has straight cut gears and the forward has helitical cut gears. Nascar uses all straight cut gears in the Jericho trannys they use and you can hear the tranny whine when they go slower like under yellow. The weight of gear oil will not usually quiet a gear set that has slop from bad bearings or worn teeth. I would check it out as I hear if a bearing ball gets loose from a cage it can get inbetween the bull gear and housing and break a hole in the bottom of the rear end and is a real pain to fix.
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
