Re: M Hydraulic System Questions
Posted by Janicholson In LA on May 25, 2007 at 22:09:00 from (65.90.227.73):
In Reply to: M Hydraulic System Questions posted by Clarkbug on May 25, 2007 at 19:26:24:
The best way to get the length correct is to use a length of old garden hose (or similar) to make the run needed. The primary important factor is to avoid the platform areas where the operators feet are normally positioned. Clips should be located to fasten the system so it does not chafe in use. George has the other question covered. I think it is close to 5.5"from the top of the pipe (or there abouts) JimN
