Re: 1530 Rear steel removal
Posted by Nebraska Cowman on May 26, 2007 at 04:19:34 from (65.165.16.220):
In Reply to: 1530 Rear steel removal posted by DCM on May 25, 2007 at 22:12:01:
Splined or keyed? They generally leak grease enough they are not froze on. The keyed hub has clamp bolts to loosen. The splined ones should slide right off once you remove the large axle nut. It helps to have a big wrench.
