Re: Farmall A Over Heating!!
Posted by Jason1(Pa.) on May 26, 2007 at 08:42:20 from (4.155.126.116):
In Reply to: Re: Farmall A Over Heating!! posted by dave guest on May 25, 2007 at 20:42:25:
Well it seems taht the block is full of junk and I'm trying to get it all out. It gets HOT fast!! You can hear it boil in the rad. Someone put a Temp guage on it at one time and its maxed out with in 10 minutes.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
