Re: At what RPM is peak efficiency (torque) for M?
Posted by CNKS on May 27, 2007 at 08:33:45 from (204.249.178.32):
In Reply to: At what RPM is peak efficiency (torque) for M? posted by M.Rad. on May 26, 2007 at 22:18:32:
An older tractor like the M was designed to be run at full throttle for "normal" loads. For light duty such as pulling a hay rake, or cultivating, they can (must be for cultivating) throttled back. For a plow, disk or shredder that is sized to the tractor, full throttle. This is not necessarily true for modern tractors which can sometimes be shifted up and throttled back for lighter loads.
