Re: narrow wheel h cross reference
Posted by CNKS on May 27, 2007 at 14:42:58 from (204.249.178.32):
In Reply to: Re: narrow wheel h cross reference posted by tn terry t on May 27, 2007 at 10:53:08:
I haven't looked them up, but if the NUMBERS are the same, they will fit. The suffix is downward compatible with the earlier version. In other words if the M has an R2 suffix, and the H an R1, the R2 will fit the H. However, I am not sure that R1 can replace R2 in all instances. Anyway the bolt patterns on the H attaching pad to the upper bolster for the H and M are different, that would account for the different numbers.
