Re: HELLPP!!! 460 U power steering
Posted by Butch WI on May 27, 2007 at 17:52:42 from (66.82.9.104):
In Reply to: Re: HELLPP!!! 460 U power steering posted by CNKS on May 27, 2007 at 14:32:25:
CNKS, There is a small gear case at the bottom of the steering shaft that contains(ed) oil. I was trying to remove the steering wheel by turning two bolts into the threaded holes on the steering wheel. I cleaned out the holes and proceeded to tighten on them(They should force the steering wheel shaft away from the steering wheel) If I am not mistaken it is a conical shaped splined shaft on the steering shaft which mates up to the steering wheel. WWhen I had what I thought was plenty of preesure on those two bolts I started to hit them with the hammer to try to jolt them free. I understand damage occurs with excessive force, so I didn't use any (so I thought) A couple minues later I had this BLACK stream running down the clutch housing. I had recently replaced all hydraulic oil. As I removed this entire steering system I figured out where the hyd system connects to the steering. But there still is the gearcase that needs lube. What type of puller should I use? I think a puller will just break apart the plastic steering wheel, unless my vision of a puller is not correct. I'll try to post a pic later!
Butch
