Re: What did you do today??
Posted by Butch WI on May 27, 2007 at 19:37:32 from (66.82.9.104):
In Reply to: Re: What did you do today?? posted by GA Dave on May 27, 2007 at 19:20:46:
David, Heres the order I removed parts untill I got to the bearing...Loosened bolt and retaining washer on the very end of the axle (it held the hub to the axle, then I slid the hub right off (easy to remove because oil leaking had it saturated to the point it could not corrode), then I unbolted the four bolt plate which has the hub seal and some felt seals in side it. but the real culprit to my leak was the oring found between the hub and the bearing. It was the last thing I removed. It took my a while to comprehend why there was oil leaking out the very end of the axle and not from that four bolt axle seal housing. It was the o-ring.
Butch
