Re: Supe M Charging Question
Posted by El Toro on May 28, 2007 at 04:14:20 from (152.163.100.197):
In Reply to: Supe M Charging Question posted by Retcol on May 28, 2007 at 03:39:24:
You can measure the charging voltage at the battery using a volt meter set on dc voltage. The engine should be at 1/2 throttle. You should
have voltage around 14.5 volts. Hal
