Steering shaft split
Posted by David Goode on May 28, 2007 at 11:40:09 from (66.82.9.57):
I was wondring if there is any whay to fix a broken steering shaft? I accidentaly split the threads on one last night on another tractor. I tride a battery clamp to pull them together and that didn't work. The steering wheel is still on. Any help is much appreciated, Thanks.
-David Goode Coggon, IA
