986 clutch dump valve
Posted by Andy Anderson on May 28, 2007 at 13:59:10 from (71.231.15.127):
986 tractor with cab and aux fuel tank has set outside over winter in western WA. The clutch dump valve is sticking in the out position but will snap back if moved a little and then the light will go out. What would cause this to happen? No apparant corrosion around the dump valve spool? Is this a common problem? I have adjusted the clutch free pedal, booster etc by the manual?
