Thanks again, guys. I alway avoid lugging any eng
Posted by M.Rad. on May 28, 2007 at 19:14:39 from (4.90.24.87):
In Reply to: At what RPM is peak efficiency (torque) for M? posted by M.Rad. on May 26, 2007 at 22:18:32:
but I also didn"t want to over-rev the unit. The disc I was pulling had a very shallow "cup" (sorry for not using the correct nomenclature-I"m new to this), and even with two cinder blocks over each set of disks (8 total), and fully "angled", it still didn"t cut very deeply. Still, the old M was never even breathing hard.
As for the throttle lever, it"s the standard type with numbers cast on top aligning with a line on the support bracket. Numbered 0-6, I believe?
Regards,
M.R.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
