Re: diesel in normal m
Posted by Bob M on May 29, 2007 at 08:04:29 from (151.190.254.108):
In Reply to: diesel in normal m posted by james in mo on May 29, 2007 at 06:21:28:
IF you have the proper distillate manifold with an operational damper and heat shield, a distillate (lower compression) head, operational radiator shutters, AND proper operating technique it MIGHT be made to run on diesel. Even then you likely will have to cut a tank full of diesel with a couple gallons of gas to get it to run.
However with the incomplete combustion on diesel (= reduced power + smoke), crankcase oil dilution issues, possibility of fouled spark plugs, possible knock damage to the engine internals, a full engine warm-up required using straight gas, etc. can almost guarantee by the end of the day you will find it's cheaper simply to run it on straight gasoline.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
