Re: 856 axle seals
Posted by dwag on May 29, 2007 at 10:37:42 from (74.40.170.74):
In Reply to: 856 axle seals posted by Todd SWIA on May 28, 2007 at 17:10:39:
Todd, You"ll probably be OK as long as everything went together OK. The proper way to set axle brgs is to lightly tighten axle cap while turning axle, then measure gap between cap and axle housing with feeler guages in 3 places. Average the 3 readings, which is the thickness of shim pack, +/- .002. It is impossible to set rolling torque as suggested on Forum.
