Farmall Tractors Discussion Board
404 ?s
Posted by Kip on May 09, 1999 at 12:50:50:
I got my Ex-cottonpicken Farmall 404 running it runs good I put rings, bearings in it and had a valve job done the tractor was a one owner it had a 314 cotton picker on it since it was new which I have removed the motor showed very few signs of wear he only picked about 200 acres a year with it. If it had'nt set up and stuck it would've had several years left on the motor Question #1 you have to have the choke about half way out for it to run what could this be.Question #2 I don't have any of the 3pt hitch arms all I have is the splined ends of the rockshaft coming out of the housing A local salvage yard has a Farmall 504 with all of the hitch intact I know the rockshaft arms will work I got the numbers off them but I don't know about the leveling asemblys or lift arms are they the same or not do any of you know THANKS
Post a Followup
: Re: 404 ?s
