Re: What engine in 706?
Posted by Owen Aaland on May 29, 2007 at 19:04:43 from (198.70.47.162):
In Reply to: What engine in 706? posted by ggg7lazy77 on May 29, 2007 at 11:42:58:
As others have said, the low ash oil is to keep the exhaust vavles from carboning up the stems. When that happens and you start to pull it hard, the stems will expand as their temeratur rises. This expansion causes them to hang in the guides. As soon as that happens it will burn the valve.
When looking for a low ash oil, look for something that has an ash content of 1/2 percent or less. They will probably also be listed for use in propane engines. Use multi grade or a straight weight as recommended for the temperatures it will be operated in.
Diesel oils will have an ash content approaching two percent. The ash is used to neutralize acids formed from sulfur in the diesel fuel. New diesel oils have a lot of changes in this area as low sulfur fuels are now required.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
