Re: Super A hydraulic pump woes
Posted by mark on May 29, 2007 at 21:11:35 from (172.164.53.154):
In Reply to: Re: Super A hydraulic pump woes posted by Karl Hamson on May 29, 2007 at 20:50:24:
Well, unless my memory fails me, there are two hard lines connected to the reservoir to and from the pump. One is the suction side, the other the pressure/delivery side. I'd loosen the bolts that fasten the return line to the reservoir when the engine is running...it should squirt oil out....seems there is an O ring in there..might blow it out too if you loosen the bolts too much. I had my reservoir off last spring and rebuilt the valve assembly...put in an entire kit. I hooked it back up, the pump self primed and the air will self purge by working the tough control levers and cycling the system. It's really a very basic and simple set up. I never had my pump off.....but, if it is a gear pump like those I have messed with in the past....it isn't anything but two meshing gears....unless there are too much tolerance between the teeth....I don't see how it can't work, PROVIDING it is turning. I'd check to see if it making pressure by cracking a line. If not, check that woodruff key as mentioned.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
