Re: Farmall H pulley lube?
Posted by Haas on May 30, 2007 at 07:34:22 from (12.65.60.139):
In Reply to: Farmall H pulley lube? posted by Aaron B on May 29, 2007 at 21:30:38:
The transmission input gear (which runs all the time the clutch is engaged) slings oil up into a channel at the top of the transmission. The oil then runs by gravity to lube all the bearing, etc, including the belt pulley assembly. Excess oil in the belt pulley gear box overflows back to the transmission. The belt pulley assembly is the high point of the transmission, and as a result, any water that condenses in the transmission housing tends to accumulate there. Run the pulley every now and then to help purge the water out. Working the tractor a little and getting it hot will help keep water out of the transmission.
